fishouttawater
- Jun 20, 2009
- 14
Hi - just installed a new 2 wire tilt motor on a 96 Mariner 40hp. Seems to work like a charm - except it only goes one way, or rather only goes one way at a time. If I reverse the green blue wire connections (ie change polarity) I can make the motor go up, change the wires to make it go down, but not up and down on the same connection. Also it tends to want to keep going with no shutoff (until I disconnect the (power) wires. If it is a relay problem why does it work both ways depenfing on the polarity? I'm not real good with electrics so excuse me if this is a stupid question or an obvious solution. Thanks.
Fish
Fish
