  #1
Old July 23rd, 2009, 12:18 AM
Striper Rig Striper Rig is offline
Wink 1979 175 hp V6 Mercury water pump???
I bought a boat today and got the motor fired up and ran for maybe 10 to 20 seconds a couple of times, but no water coming out of water pump hole...
Made sure it was not stopped up, I only saw a very little surge of water...
My ? is can you try anything to get it to work?
Also if I have to put a kit in it, where is the water pump located and is it hard to work on?
The motor sounds strong no longer than I ran it...I did not want to mess the motor up by running it to long, but I know I ran it long enough to come through the hose and out the pin hole....
1979 175 hp V6 Mercury...thanks for your help...
  #2
Old July 23rd, 2009, 01:11 AM
j_martin j_martin is offline
Default Re: 1979 175 hp V6 Mercury water pump???
Sometimes it takes 21 seconds.
Seriously, the motor has to warm up to operating temperature before there will be any output from the telltale, because all the water for the telltale goes through the thermostats first. If you can hold your hand on the head, it isn't warm yet.
Did you have it on a hose, or in the lake?
If on the hose, water will come out of the prop long before it comes out the telltale.
If on the lake, a little spray mist out of the exhaust relief ports indicates it's getting water.
Spiders and wasps have a way with tell tales, also.
To service the water pump you have to drop the lower unit. It isn't hard, but is a bit involved. Get a factory maintainance manual and have at it.
Water pump maintainance should be considered an annual event.
hope it helps
John
  #3
Old July 23rd, 2009, 07:57 AM
Thanks j martin, this does help me out....
I will go back and try again, plus I may use a half of plastic barrel to put the shaft down in....
  #4
Old July 23rd, 2009, 11:12 AM
The best bet for quick testing is the muffs that fit over the water intake holes. You connect a garden hose to it, turn on the water full blast, and run the engine.
that way, you will see water out the propeller immediately if the water pump is working. It also makes a mean snarl exhaust note that is kinda neat.
A barell full of water will overheat in a few minutes of running. Idle fire in the motor is about 3 Northern Minnesota houses worth of heat. (WOT is about 30)
  #5
Old August 7th, 2009, 09:40 PM
J Martin,
I talked about this a while back, I put a new impeller and gaskets in the footing...
I still have only about a 7 inch stream coming from the pee hole...ran about 4 or 5 minutes, head never really got hot...
The two little muffler holes at the back of the motor, pushes water out pretty good...
So that should tell me the water pump is working, what should I look for next? I thought there should be a good stream coming from the pee hole...
I have checked the hose to make sure it is free from dirt dabbers...
Thanks...
  #6
Old August 8th, 2009, 02:15 PM
Anyone's help is appreicated....
  #7
Old August 8th, 2009, 03:21 PM
Yer good. Here's the deal. Only when the engine is warm enough to open the thermostats is there any water in the line that goes from the thermostats to the baseplate. The baseplate end of that line is open to the foot for drainage. The tell-tale T's into that line. There never will be a lot of pressure there.
The best use of the telltale is this. When you start up at the lake, and you're all excited to blast out of there, you turn around and be sure the telltale is flowing some before you blast off, else you might cold-stick the engine.
If the engine were overheating, the alarm would go off.
If the engine were overheatging, you'd leave some flesh on the head.
Go burn some fuel. If you're really concerned, put a water pressure gauge on it. I consider a WP gauge indespensible on my boat. It gives me instant indication of the performance of my cooling system.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 7.5HP ES, Water Pump Refurb troyt Mercury & Mariner Outboards 12 December 30th, 2007 09:55 PM
Evinrude 1979 25 HP Water Pump Mt Pleasant John Johnson & Evinrude Outboards 0 April 11th, 2007 05:31 PM
15 hp Rude 1979 Water pump kit michiganmarty Johnson & Evinrude Outboards 3 October 27th, 2003 12:38 PM
Johnson 1979 4HP water pump kit Lyse Johnson & Evinrude Outboards 2 May 1st, 2003 07:05 PM
1979 Johnson 4hp Water Pump Ranger Dave Johnson & Evinrude Outboards 5 April 5th, 2003 01:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
