bear_69cuda
- Oct 10, 2008
- 2,109
Morning Gang,
My Trim Reservoir seems to be leaking, so I'm looking for a replacement.
I understand there is a single screw type, and one with 4 screws that attach the pump/motor. Mine is located in a tricky spot for viewing...
My drive is a 1999 Alpha I gen II drive SN: OL448413
My Engine is a 1999 3.0L SN: OL337309
Can I determine what type of reservoir I have from these SN's, or do I need to remove the pump assy?
If I have the single screw type, I hear there is a update kit with new pump, but sounds expensive. Should I update or just get replacement reservoir?
If I have the 4 screw type I'll just get the replacement...
Thanks in advance!
Thanks in advance!
