ok,
so i have read all of the posts and replies on the issue of converting a 90 h.p. johnson to a 115.
i don't think i am confident that there is any solid proof of what needs to be done here.
so i want to start a new post with replies from only 100% confident mechanics.
so lets settle this for at least a 1983 90 hp
1. my 90 has a flat back exhaust cover and so do the two 83 115s that have witnessed. could i take those carbs off the 115s and put them on my 90 and have a 115? or if not will i see any improvement with no other mods or am i looking at trouble?
2. does the bubble back 115 have any (deflectors) or any other parts that my local salesmanistic mechanic suggested they had. or was he just trying to get me to buy a motor off him? and why do the two 115s that i've seen have flat back exhaust covers? what else could fit in there that the 90 doesnt have?i assume the bubble is somewhat like the expansion chamber on a 2-stoke dirtbike?
3. and finally,
can i just throw the 115 carbs on there and get some kind of gain without changing the heads and without doing any porting......as far as i know from my manuals the bore, stroke, timing, crank, pistons, and every single other part that i could posibly compare between the two are identacle with an exception to the block.
i begg of someone to read this and clear things up for e for i think it would benifit many, and clear up any confusion.
thank you
nick.
3. and finally,
thank you
nick.
