matt88
- Mar 17, 2009
- 160
Was having a problem with the prop slipping and tried some doel fins to compensate. The fins solved the slippage problem but I have lost about 3mph on the top end. When the boat is on plane the fins ride just under the water. I thought they were supposed to skim just above the water line. Is this correct? Im not sure but Im thinking that my motor height should be a little lower without the fins(obviously) or a little higher with the fins. Does this sound like the correct remedy? Also which would give me more overall performance with or without the fins? Have tried different tilt settings but the optimum setting is where my prop will occassionaly slip. thanks
