  #1
Old July 21st, 2009, 10:24 PM
Shay07 Shay07 is offline
Default Mercury 800 80hp, won't go past 2500 rpms
Hi all i'm new to iboats and boating hoping i could get some help with my boat, So I bought a boat 17' with a 70's Mecury 800 80 hp motor. It is hard to start most the time until it's warmed up, it runs fine on muffs, revs up everything sounds great but when i put it in the water i can only get to about 2500 rpms, last year it would bog after about 2 minutes running at 2500 rpms. This year i've had a friend come and help me with it, we've changed the spark plugs checked out the distributer(it's ok but was pretty corroded we cleaned it up pretty good though) we've also adjusted the screws on the carbs as best we could and it runs now better than when i got it, It doesn't bog anymore but i still can't get more than 2500 rpms. i probably need a distributer but was wanting to find out for sure before i buy one,
Thanks,
Shay
  #2
Old July 21st, 2009, 11:35 PM
coolguy147's Avatar
coolguy147 coolguy147 is offline
Default Re: Mercury 800 80hp, won't go past 2500 rpms
ok well first off check compression make sure thats good. then check spark. might as well replace ur water impeller. check gear oil and replace. once u fingure out u have a good motor.
then after might as well go and clean and rebuild ur carb. then see if pumping ur primer bulb will help with the rpms if does then rebuild fuel pump and be safe replace fuel lines and such
__________________
http://photobucket.com/sgdteam
  #3
Old July 21st, 2009, 11:36 PM
Fuzzytbay Fuzzytbay is offline
Most inline 6's are a bit hard to start cold, you need to almost flood them to get em going, once warm they start fine. Now I am guessing at the age of the motor, posting the S# would help. Since your new, and to you so is the boat and motor, you start with the basics, look at the plugs, test the engine compression, clean the carbs, and do a link and sync. The first test is pretty simple, pull the plugs, look for even colouring, a brownish colour's good, with no build up of oil, metal etc. Second once the plugs are out, check the compression, the cylinders should all be within 10#'s of each other, 110-130 would be good, 90-110 should still run.third one might be tricky, if you have never done it, but with the help of this forum, its not all that hard. Here is a link to the fourth item, the link and sync. http://forums.iboats.com/showthread.php?t=168855
I wouldn't start buying parts, untill you narrow done the problem, to me sounds like simple stuff, more like a fuel/air mixture issue, or even incorrect prop pitch.
  #4
Old July 22nd, 2009, 09:51 AM
coolguy147's Avatar
i guess go ahead check ur prop pitch and make sure at the controls the butterflys all of them r wide open
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
johnson 40hp won't rev past 2500 rpms brisboats Johnson & Evinrude Outboards 4 July 11th, 2009 11:22 AM
Won't rev past 2500 bman1bpm Force & Chrysler Outboards 20 July 6th, 2009 12:26 AM
*100 Hp yamaha bogs down @ 2000 rpms (accelerating) runs fine past 2000 rpms* Help!! sound120 Yamaha & Suzuki Outboards 0 May 25th, 2009 11:39 PM
Wa,wa,wa,wa,wa, 2500 Rpms AQUASPORT17.5 Johnson & Evinrude Outboards 9 July 31st, 2007 05:50 PM
OMC 305 GM STILL will not go over 2500 rpms kicks2 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 September 16th, 2003 10:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
