Schaefercal
- Jun 29, 2009
- 3
I need Ideas! I think i"ve read all the posts concerning these older style CD ignition systems and how to trouble shoot them. I do have a manual but am having problems in the fact that my issue is intermitent.
- 1968 85 hp Evinrude Model 85993 with the CD style ignition
The motor will start great, run forever at home at idle on the muffs. It will run for a while on the water but after 2-4 mins of running at power the motor shuts down like someone turned off the key. No coughing, sputtering or other, just shuts down and will not restart. I tested for spark when it shuts down on the water and have no spark at plugs or coil. Usually after an varying amount of time the motor will start again and run for a minute more before shutting down again. Coil? Amp? Would the amp be intermittent like that???
Any help would be great!
Thanks
Thanks
