I have a 2006 Mercruiser/Cummins Diesel in a Trophy 2052, it has the MERCRUISER1.7 MI 120 hp.
I recently changed the fuel filter to try to stop an alarm condition. I had checked all the fluid levels and found none to be out of line.
I kept at it and found there is an alarm for fuel contamination. I found water in the fuel/water separator, changed the filter and drained the water off. I checked it again and there is no water accumulation. The problem now is the alarm will not stop. After I start it and the oil pressure goes up it stays on. I have verified all the fluid levels and purged the water from the fuel water separator. Are there any alarm conditions I could be missing? Is there still a potential fuel issue? If anyone knows the alarm conditions that may help. If you know how to reset the alarms that may help as well.
