Jynxs boat
- Jun 28, 2009
- 11
Hello,
I've been in and out of this forum a dozen an one times the past few days, and I believe I'll be in here for quite a few more. You see I'm attempting to restore an old 1964 17ft elgin with matching 45 hp motor.(I believe thats what it is anyway)
The problemo is...
1) The wiring from the motor to the ignition, as well as the ignition is sitting in the bottom of the boat. There are only 4 wires there. Red, Black, Green, and White. Theres a buss on the inside of motor with matching colors, so i kinda figured that part out. The other end of the wires go from the motor to the front of the boat, and I believe go to an ignition switch but don't know how to put em in sequence,since the old one was all jerry rigged and rusted, I pulled it out and picked up a new one from shucks. It seems like I should have a couple more wires there, but not sure what.
2)I have the battery connected to the starter seleniod and the motor chassis, should there be another wire from the battery to the ignition?
3)I'm not sure of the fuel mixture
4)Definately not sure of the starting procedure.
5)Where would can I find the electrical parts I would need
The model number on the motor says 574.6061.
At anyrate, if anyone's got a wiring diagram, or any tips concerning this post, It would be greatly appreciated. If I can help anyone out in any way, I'm a residential electrician. Feel free to PM me.
Here's some pics of my ordeal!
The problemo is...
