Re: 1993 Johnson 115 leaking gear oil at prop
Welcome to iboats.
Are you sure it is lower oil?
If oil is coming out then water is certainly getting in, have you drained the lower to check the oil, if you have a bad seal it will be milky looking instead of the nice honey color.
Alot of times some unburned fuel and oil will come out at the prop, if the oil is black that is probably what you are seeing and that is normal, if it is actually lower oil that seal can be replaced but if memory serves it can be a bit of a pain to do.
