Re: Weak Power Trim Mariner 40hp
I found the release value on the reservoir at the base of the pump. Can't believe I didnt see it before. Just have to unscrew with flat head screw driver.
Anyway, I lifted the trim all the way up, opened up the release valuve to let the motor down, (thinking this would help bleed the air our, did this 3 or 4 times) but no such luck.
Trim still goes up and down but when I apply pressure while trying to lift the trim its still to weak to lift.
I don't have a manual yet. I have one on order with the local marine shop but won't be here for another 2 weeks.
With out taking the entire power trim off I can't locate any relief valves top or bottom of the cylinder, only reserve pump.
I'm starting to think the problem is with the seals, perhaps air is leaking out and not able to build enough pressure. Again I have no oil leaks anywhere.
Any help would be appreciated.
