What is involved or will it work if I use a 1979 power pilot for a 1976 115 motor? Thanks in advance
A Art Burkett Cadet Joined Jun 22, 2008 Messages 9 Jun 28, 2009 #1 What is involved or will it work if I use a 1979 power pilot for a 1976 115 motor? Thanks in advance
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Jun 28, 2009 #2 Re: power pilot interchange if motor end of cable will work on the motor. there was a change in 1979. you really need a 1978 or earlier control.
A Art Burkett Cadet Joined Jun 22, 2008 Messages 9 Jun 28, 2009 #3 Re: power pilot interchange Thanks for such a quick response. I believe I've got the throttle cable and shift cable to hook up but I'm concerned about the electrical connections are these the changes you referred to, could you be more specific. Thanks Art
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Jun 28, 2009 #4 Re: power pilot interchange you have the big red plug on your wiring harness, it is just plug and play. they are alike since 1973.
