71 20 horse miss and gear engagement problems
NMfshrmn
Hi,
I just completed a tune-up on my 71 20horse motor. It ran great for a while, and then I ran it WOT to see if the performance was back. It was, until two problems started. First is I get a miss pretty regularly (like the engine shuts down for a split second), and secondly it started popping out of gear into neutral unless I hold the shifter with forward pressure. I'm going to see if there is some linkage adjustment for the second problem, but not quite sure where to look for the first. Carburetor? I removed it and did a cursory cleaning as it looked pretty good, but not a full teardown. I did plugs, points and condensors in tuning.
Any ideas on either problem greatly appreciated. I've done quite a bit of work on 4cycle motorcycle and auto engines, but not much on 2 cycle.
Thanks,
Joe
NMfshrmn
Re: 71 20 horse miss and gear engagement problems
I forgot to say that it's a Johnson manual start 20.
NMfshrmn
Any ideas at all. The miss almost seems like it could be no fire to the plugs for one cycle. Could something be grounding out somewhere?
