hello all, i have a 1995 mercury 60 hp on a 17pro bass tracker. the problem i am having is that the motor runs great when i first put it in the water. it runs strong on long runs. after a while of idle or slower speeds the motor will sputter at the high rpms. it sounds like a stall converter on a race carr. it seems to hit about 3000 rpm and then begin the stalling and will not go over the rpm. it is almost as if the carbs are not getting air or fuel. if you let it sit for a while it will start running good again. please help in any way.
