86 mariner 75hp idle
the motor is rough to start, it starts when i idle it up and choke it, it will run strong afterwards. every time i shut it off for a short period of time i need to still idle it up and choke it even after its still warm. after that ill put it in foward... the idel will drop and it will stall... not everytime though. im messing with it at my house with the ears. i have a spark stop adjustment screw, a throttle stop screw and finally a idle stop screw.. there is another screw or bolt w/e on the spark stop lever mid way down smaller bolt then the rest... i turned that bolt out to get it to idle a little higher...but what does that actually do? should i use this to idle it up a little more? my problem is that i need to actually move the idle up once it is in gear if possible... idle in neutral is ok but i still need to throttle it up to get it running after its warm when im out on the lake.. i have been a small engines mechanic for a long time... i just dont know jack about outboards... got the boat/motor used had to replace lower unit... other then that when im out on the lake and the motor is running.. it runs good
