welovetoboat
- Jun 3, 2007
- 23
We have a 305 228 hp mercruiser in our 1979 Formula. It does not seem to have much power getting out of the water. After planing (which is tough) it will run for a bit at wot and then just die out. Most of the time it will start right away after it dies and sometimes it has to sit a couple of minutes.IT IDLES GREAT. Can go all day at a VERY LOW SPEED. When the issue happens there in NO FUEL in the filter. I have changed the fuel lines, filter, water separator, spark plugs and distributor cap. My thoughts are it may need a new fuel pump or there is junk in the tank gettting sucked up. Any help or suggestions would be appreciated.
