CATransplant
- Feb 26, 2005
- 6,319
I change lures a lot while fishing, and digging in the tackle box is a hassle. I just found a great solution for my aluminum boat. I cut a 3' piece from a swimming "noodle," then hot-glued it under the gunwale beside my usual fishing position.
Lures hook right into the foam, and come right out without hanging up. So, now, I can line up my favorite lures and switch back and forth with a minimum of delay.
You could also use foam pipe insulation, but the noodles are cheaper.
