  #1
Old July 20th, 2009, 03:33 PM
dax0260 dax0260 is offline
Default Mercury 115 - Drive Shaft Housing Removal (possible or not?)
I accidentally pushed the lower rubber grommet that seals the water tube at its access hole located at the very bottom of the drive shaft housing UP INTO the drive shaft housing. Proceeded to try and fish it back down into place with a fish hook and lost the fish hook into the drive shaft housing as well. I need to get in there so I can remove the fish hook and put the grommet back in place around the water tube.
Stupid mistake that may have just cost me a lot of money?
I'm wondering if it is possible to drop the drive shaft housing off of the upper unit without having to disassemble the engine from the top down. That's my primary question right there and any help would be greatly appreciated.
There are the 8 obvious bolts holding the drive shaft housing onto the upper unit, but then there are two smaller bolts that seem like they can't be removed without removing the steering swivel bracket.
If I can drop the housing without having to get too crazy, I can do this myself, but if this will require large scale dis-assembly, I need to take it to a professional.
Also, just so I know, would it be a problem if I just pushed the old grommet up the water tube and out of the way, replaced it with a new one and just left the little fish hook where it is in the drive shaft housing? Could that fish hook cause a problem for me if it's just sitting in there?
Thank you guys in advance for any advice you may be able to offer!!
-Dax
  #2
Old July 20th, 2009, 04:09 PM
emckelvy emckelvy is offline
Default Re: Mercury 115 - Drive Shaft Housing Removal (possible or not?)
You're gonna need to pull the powerhead and remove the exhaust adapter plate to repair this problem correctly. Any other attempts to Band-Aid fix will only result in a compromised cooling system and VERY $$$$ engine problems.
Note that if your 115 is '72 or newer, the exhaust tuner plate has internal bolts which can only be accessed with the powerhead removed. Even if it's the older design which has no internal bolts, the powerhead attaching bolts go all the way thru the exhaust plate into the center section, so you'll have to pull the powerhead in any case.
BTW, the (2) nuts at the front are thinner and can be removed in place. If there's not enough clearance for you to get them free, once the powerhead is lifted just a bit the nuts are easily removed.
HTH.........ed
  #3
Old July 20th, 2009, 04:18 PM
Ed - Thank you very much for letting me know. I thought this would be the case so now I can stop searching for an easier fix.
Just so I know what to expect from a marine mechanic, roughly how much money should I expect to pay for having my power head removed?
Again, thank you very, very much for this advice.
-Dax
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 20hp 1980's Drive shaft housing plug Flipperjack Mercury & Mariner Outboards 3 July 8th, 2009 03:41 AM
DT140 Drive Shaft Housing LARSON69 Yamaha & Suzuki Outboards 0 June 16th, 2008 04:34 PM
Drive shaft housing temperature? Medvind Mercury & Mariner Outboards 2 July 19th, 2007 09:32 PM
Mercury 25 - Cracked drive shaft housing jakeboomer Mercury & Mariner Outboards 3 February 2nd, 2005 01:15 PM
78 merc 700 drive shaft housing removal dnorm25 Mercury & Mariner Outboards 1 April 19th, 2004 10:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
