  #1
Old July 20th, 2009, 02:10 PM
efcon efcon is offline
Question New boat owner question - Gas consumption
I recently owned my fathers boat and i have a question. Is there a way to calculate the gas i need when i wanna go fishing or a small trip? Im new to all this and im looking for how much litre per hour for example the boat engine is consuming.
The boat is a 13.8 feet (4.2 meters) inflatable boat with a Johnson 40 (2000 model, BJ40PLSSM) and im running it in seawater.
Thanks in advance.
  #2
Old July 20th, 2009, 05:07 PM
RWilson2526's Avatar
RWilson2526 RWilson2526 is online now
Send a message via AIM to RWilson2526
Default Re: New boat owner question - Gas consumption
they do make electronic metering devices that you put in line between tank and engine that tells you your consumption...not sure about mounting it on an inflatable though although you could probably figure it out....
What size fuel tank does it have? I would fill it up everytime I go out and then look and see how much is left at the end of the day and start to get a feel for it that way......
you should be able to find information about the motor online that should give you expected fuel burn at varying RPM's you could look at that to at least give you an idea.
__________________
1986 Wellcraft V-20
1986 Yamaha 150 hp
  #3
Old July 20th, 2009, 06:06 PM
Fl_Richard Fl_Richard is offline
Master Chief Petty Officer
That motor should burn around 4 gallons per hour at WOT (wide open throttle) and considerably less at lower speeds. I would assume for open water travel you'll probably burn 2.5-3 GPH. If your in heavy seas more flat water less.
I'd filler up when you leave then re-fill when you return. That will give you a good idea.
  #4
Old July 20th, 2009, 08:16 PM
a70eliminator a70eliminator is offline
However much fuel She guzzles always stick to the one third two thirds plan.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Question from 1st Time Boat owner? Bandneil Boat Topics and Questions (not engine topics) 4 July 20th, 2009 08:07 PM
Possible first time boat owner question? btowndms Boat Topics and Questions (not engine topics) 8 June 4th, 2008 08:08 AM
***Prop Question?**(new boat owner) Campnc Prop Questions and Topics 4 July 1st, 2007 09:44 PM
Prop Question(New boat owner) Campnc Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 30th, 2007 07:34 PM
Old Boat... New Owner... VRO Question brettagostini Johnson & Evinrude Outboards 6 July 15th, 2003 12:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
