  #1
Old July 20th, 2009, 11:57 AM
jetty22 jetty22 is offline
Default Dealer Flushing Adapter for a Mercury SportJet?
I have a 1993 Bayliner Jazz with a Mercury SportJet 90. It can be flushed at the top of the cylinder head or through the engine cooling hose. Apparently, you can only run the engine when you flush it by the cooling hose but.. I need an adapter for it. Does anyone know where to get the adapter for the engine cooling hose or the dimensions for it?
  #2
Old August 13th, 2009, 11:26 PM
x1745 x1745 is offline
Default Re: Dealer Flushing Adapter for a Mercury SportJet?
Flushing Cooling System
Flushing the cooling system is essential after each use in salt water, after the boat has run
aground, or when the overheat warning horn sounds (debris in jet powerhead). We recommend
using Dealer Kit (P/N 22-820573) to flush the cooling system.
1. Disconnect the inlet water hose at the rear starboard corner of the pump housing. Install
the Dealer Kit and attach water hose.
a
a - Dealer Flushing Kit (22-820573)
2. Turn water on and flush engine block for at least 10 minutes.
3. Remove water hose and dealer flushing kit. Re-install water inlet hose.
4. Flush outer surfaces of water outlet nozzle with water stream
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
flushing adapter kwango Mercury & Mariner Outboards 2 February 22nd, 2008 12:42 PM
Adapter for flushing 9.9 hastingsml Yamaha & Suzuki Outboards 12 July 20th, 2007 03:45 AM
OMC Flushing Adapter Kit Lyndy Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 January 12th, 2007 10:56 PM
Winterization Flushing Adapter?? rapa123 Four Winns Boats 3 October 23rd, 2006 09:53 PM
Flushing adapter on 150 Yamaha...good or bad idea BTurville Yamaha & Suzuki Outboards 8 January 9th, 2003 01:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
