Help Please!!
jdmef270
Hello i have 1989 4Wings 195 boat. I was looking for the boat you unscrew for the prop and i accedently unscrewed a bolt that have a nut on the other side and the nut dropped in were the gear oil is, this is my first boat and wasnt aware of the nut being there/ not being tacked. so what do i have to do to fix this, can i just leave the nut in there or will it get in the gears for the prop, help please!! thank you!
Moody Blue
Re: Help Please!!
Not familiar with your boat/motor but I can't see how you could mistake what nut to remove for the prop. Don't know what bolt you are referring to that would have an unsecured nut on the back side. In any case, in my opinion, you must get that nut out if it ended up in the gearcase. What size bolt was it?
jdmef270
Re: Help Please!!
it wasnt to big, but how would i disassemble the gearcase to get the nut out?
mars bar
Re: Help Please!!
My friend, I think a manual would be a good start. To try to explain that would take up a lot of time.
Moody Blue
Re: Help Please!!
If this is an I/O drive then you would get better advise in the I/O section. Perhaps a moderator can move this for you.
jdmef270
Re: Help Please!!
ok, so i was looking at it, and there is oil in the top, and oil on the bottom, so the bolt fell inbetween were water goes, which i believe is called the stern. thats were the nut fell in, will it be ok untill i can get it to a shop?
mphy98
Re: Help Please!!
POST PICTURE. no one here can guess what you are doing.
tx1961whaler
Re: Help Please!!
No, take it to the shop.
Moody Blue
Re: Help Please!!
I think you are confused about the proper terms. You are certainly confusing me :D. I have no idea what you are describing. A picture would be a really good idea.
1960vw
Re: Help Please!!
If there"s room, try using a long mechanics magnet. Some times its along metel rod, sometimes a long spring with magnet on end. You can get one at Harbor Freight for about 4 dollars. Fish out the nut/bolt that way.
kg5388
Re: Help Please!!
1989 195 Freedom fourwinns is most likely what he has with the cobra outdrive. he unscrewed the screw on the side of the outdrive above the vent fill screw for the lower unit lube that should have the cobra badge covering it.
the out drive will have to come apart to get it out and put it back on.
