Re: early 1980s mariner 80 dont wanna idle and bogs out at full throttle
I think you have two related problems. First perform the "link and synch for merc inlines" that is posted as a sticky. This will get your carbs synched with the spark advance.
Next you need to adjust the idle mixture. Start with the idle mix needles open 1-1/2 turns from lightly seated. The motor should run fine on this setting in neutral. Now put it in gear and try to accelerate. If it bogs or stalls, open the top carb 1/8 turn and try again. Repeat with bottom carb, then top carb, ect, testing after each adjustment. Eventually you will find a setting that allows reasonable idle, and good smooth acceleration.
