I just adjusted the throttle linkage on my '73 25hp Johnson by following the Seloc manual. The adjustments should be correct for the low range, but it appears when the controls are WOT there is still a few degrees left to open the throttle plate. Is this Ok, or will I get a few more RPMS by adjusting it so it is all the open?
