Shouldn't Have
- May 5, 2009
- 37
I have twin volvo AQ260A engines. Purchased boat last spring. I have done the following:
Replaced plugs and wires.
Replaced distributor cap and rotor.
Replaced ignition coil on port, starboard appears to be relatively new.
Took off carbs, cleaned and put in new parts and gaskets from rebuild kit.
Replaced inline fuel filter and water separator filters.
Both engines are running great at cruising speed anywhere between 2400-3000 rpms. They both hold a very steady RPM, I have digital tachs, so I see it all.
Port Engine--
In neutral I have it set to idle at 550. It holds it well and only fluctuates by 20 or so RPMS, drop it into gear, it goes down to 440 or so and holds it well.
Starboard engine--
In neutral I have it set to idle at 700 or more. Fluctuates by 80 or more RPMs. I drop it into gear and it falls below 350 RPMs. If it doesn't stall, it will come back up to 500 RPMs, but does not hold it well, fluctuating quite a bit, and if left in gear long enough at idle, it will most likely stall. Increasing the neutral idle speed will decrease my chances of it stalling, but then it is just too fast. I have adjusted the idling mixture screws, in/out and every which way.
They both have Rochester 4ME carbs.
Any suggestions on how to fine tune this engine to get it to idle better?
-Scott
Port Engine--
Starboard engine--
-Scott
