Put her back in the water, drove it to the house from the boat launch and it ran much better, much more power but in the mid range rpm it still runs rough, especially when slowing down. I had to adjust the idle but I still didnt get it perfect, I guess Im suppose to disconnect the idle speed adjustment before adjusting the screw for the timing bar? Anyways, it keeps prime now. I cant see any more visable leaks but my brand new dry hoses are wet, and oily. So.. Maybe it's still leaky vacume/fuel or somthing?
It still doesnt want to idle without loading up after a couple minutes and going from nutural to gear idle it will shut off, I gotta give it some throttle and then go back to the idle "click" on the throttle. But thats not idle speed, it's a little higher...
When restarting after warm, it will restart ok if I use the idle bar a little, but if it "SPITS!" then its a PITA to start. I normally have to put the idle bar all the way up and bump the choke and put some fuel on the plug to bust it off and clear out the load up...
I took 2 friends for a ride today, weighing about 260lbs each, plus me which is 150 and I got the overheat horn a few times and the "rev limiter" effect again. Maybe Im stressing the motor out with all the weight, it struggles alot to get on plane with all of us.
Well, sorry for the long post but I hope someone can help me.
Im still working on getting a model # but we're all pretty sure it's a 1989 engine.
Thanks again!
Thanks again!
