ourkid2000
- Jun 24, 2009
- 13
Ahoy folks........
Now that our outdrive has been identified, with many thanks to Bruceb58 & WizeOne, I now need to figure out what has actually happened to it.
Turns out it is a OMC Stringer drive - Mechanical Shift attached to an OMC 2.5L 4cyl engine (inboard/outboard). The boat was supposedly made in 1986, however, the Stringer Drive is 1978-1980 vintage.
The first thing we did was pull up the box covering the motor, and look at the linkage. There is a white plate with Forward and Reverse marked on it with markings in between.
All we really did was verify that this linkage was moving. And it was, you could watch it move with the throttle settings. I didn't hear any nasty noises when it happened, it just seemed to slip right out of gear.
Other than that there wasn't much we could see out on the water. What would be the next step?
