  #1
Old July 17th, 2009, 09:33 PM
SpeedifourButch SpeedifourButch is offline
Default '96 150 Evinrude Ocean Pro gauge wiring
I have a 1996 150 HP Evinrude Ocean Pro with Optical Ignition. The model of the engine is E150EX. It is on a 1981 Grady White Overnighter that I have totally restored, and the boat had no gauges on it before. I have hooked up the voltmeter. I need to know where to look for the wire for the tach, ( I believe it comes off of the alternator), and the wire coming off of the tilt/trim switch. If anyone could give me the color and location of the wires I need back by the motor I will run it up to the sending post on the gauges.
Thanks in advance
  #2
Old July 17th, 2009, 10:07 PM
wilde1j wilde1j is offline
Default Re: '96 150 Evinrude Ocean Pro gauge wiring
The wire should already be in the harness that goes forward. My '85 Johnson had a plug on the binnacle for the tach connection. The wire with the mating connector for the tach came with the controls wiring package. It was really simple. You need a wiring diagram for YOUR motor or a conversation with your local BRP dealer.
__________________
Jim
  #3
Old July 17th, 2009, 10:54 PM
There is no original wiring harness in the boat. I do not have a owners manual and cannot afford one, hence the posting on this site. I appreciate your response, but at the end of the day, what good does it do me. Please commander, let someone with a manual tell me what the color codes are for the wires I asked for in my previous post.
Thanks in advance
  #4
Old July 17th, 2009, 11:36 PM
bob johnson bob johnson is offline
do you at least have a wiring harness coming from the MOTOR????
the wire will be gray anyway..
but the first guy trying to find out what you have..
if you dont have a wireing harness at all from the motor, then it doesnt matter what color the wire you dont have is!!!
right?
I have a 1997 evinrude Ocean Pro 90 hp
and it has a huge PLUG with 8 wires that goes to my tach( the tach has a reciever for that plug.
but my MOTOR wiring harness ALSO has a spare gray wire to hook up to a different style Tach....
Like I have a Tiempo( light blue body) that has seperate wires... and I have the red tach with the plug fitting.
the tach also needs the light supplu wires.. and an ignition( purple) wire hooked up so it turns on when the keys is on...
unless of course you have the 8 pin plug on your MOTOR wiring harness
if you dont have any wiring coming from your motor into the boat...you have greater issues
good luck
bob
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
need help with evinrude trim gauge wiring SEGER Johnson & Evinrude Outboards 3 August 13th, 2009 08:22 PM
2008 Evinrude 90 HP E-TEC Trim Gauge Wiring tawakoni Johnson & Evinrude Outboards 4 July 27th, 2008 11:48 AM
96 evinrude 115 gauge wiring stilesn Johnson & Evinrude Outboards 2 April 15th, 2008 12:50 PM
evinrude ocean pro 150 wiring help robert mckenna Johnson & Evinrude Outboards 8 June 25th, 2004 07:04 PM
Wiring Evinrude T&T Gauge rickdb1boat Johnson & Evinrude Outboards 0 May 28th, 2002 09:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
