I have a 1986 Johnson 90HP outboard, took it out on lake and ran fine almost all day, later it started smelling like gas and running rough and very shortly after that it died and would not start, leaving me stranded on the lake. I pulled the plugs and the two on the right were fine but both plugs on the left were soaked in wet gas, I replaced them with two spares I had and it ran for a few minutes before fouling them also. I thought that the lower cylinders were fed by lower carb and upper cylinders by upper carb. So now I cannot see how wet plugs could be caused by a flooding carb, since both plugs are on left. Am not sure where to go next.
