I have recently purchased a QD-13 Johnson 10 hp motor off of Craigs List. In the middle of restoring it have run into some problems...minor ones, thank goodness but a couple of head bangers as well. My problem here in lies is this...during the rebuilding of the carb...the float is positioned off center causing the float to hang on the wall of the bowl and the needle valve has a slight wear ring around the needle point. I don't know if i'm looking in the wrong place, but where can i get a new float and needle...have tried fixing the float with epoxy. And even considered using dope that is used on model airplanes (fuel resistant), the reason for that is i had to trim some of the float away to reset the bracket on it that conects to the needle inside the bowl...any ideas and helpful hints are appreciated.
