Ive posted allot on here before with my 1981 Project Mark twain. with a mercruiser 260 and alpha drive. To make a long story short a machine shop is building me a engine. The block is a two piece main seal, left hand dip stick. I'm putting a crank and cam out of a 1984 mercruiser 260 in it, he polished the crank and the cam is in excellent shape. He bored the block 30 over, getting new pistons, the connecting rods out of the 1984 260 were good so he's using them, new lifters, rods and rockers. 882 heads with z28 valve springs and the intake off the 1984. I also want to use the thunder bolt ignition off the 84 to replace the points. I'm putting in the inner transom plate off the 84 and putting on a 1988 outside gimbal housing and using a 228 upper with a alpha one lower. I had a lot of advice about getting a new engine or vortex heads and such but this is what I was able to come up with for the money I had. I guess I should call it a MUTT but would I identify it as a 1984 Mercruiser or just write down what all I just wrote and if I need a part identify everything like that. Plus If I sell it I don't want no one looking at it to be fooled or misled.
