sunchasers
- Jun 23, 2009
- 6
i have the above mentioned motor. I am trying to replace the steering pivot/knuckle. I have the nut removed from the shaft that runs thru the pivot but the shaft will not let loose. Is the shaft press fitted or threaded? Any advice to remove will be greatly appreciated. thank you.
