  #1
Old July 16th, 2009, 04:43 PM
larsst185 larsst185 is offline
Default Slant back for capri 1800 1990 model
Hi
Can someone tell me where I can get a slant back (it that is what it called) like the one in this video.Would really make my boat better to use in rain
http://www.youtube.com/watch?v=XfdpbNjKzyQ
  #2
Old July 16th, 2009, 10:23 PM
azlakes's Avatar
azlakes azlakes is offline
Default Re: Slant back for capri 1800 1990 model
...hiya lars,
Its called a bimini top, yup excellent for sun and rain. You can get several styles and makes. Look here on iboats in the internet marina. you can have the type that folds down completely or stands erect with rear supports like in the vid. measure carefully the width of your boat at the console and then whether you want low or high profile. Many sites will give a best fit.
http://biminitops.iboats.com/?******...****=141158816
Enjoy
__________________
86' Capri 1950 BR
Force 125hp
Desert Southwest
  #3
Old July 16th, 2009, 11:19 PM
redone4x4's Avatar
redone4x4 redone4x4 is offline
Send a message via Yahoo to redone4x4
i got mine as tall and wide as possible...so i can walk under it easily, and so it covers as much seating as possible. worked out great, best purchase i made so far on the boat.
__________________
Samuel Adams. Always A Good Decision.
1987 5.0 OMC capri 1950CX bowrider, 3 bow 6 ft. Westland bimini
  #4
Old July 17th, 2009, 07:19 AM
Red face Re: Slant back for capri 1800 1990 model
Ok thanks.How does the bimini top handle wind?It seems a bit flimsy?Is there any alternative to the bimini top?Something that fits around the windows making it more rigid when running the boat in some wind.I dont know the correct word for what im talking about...argh!Like a harbour top just a bit taller.
  #5
Old July 17th, 2009, 10:27 PM
azlakes's Avatar
... you can opt for stainless steel hardware for the truss mounts, you can put a wood or metal back plate to help strengthen the bind of the mounts as it sandwiches the fiberglass, it will hold up to moderate speeds and winds pretty good. if your windscreen and boat railings have gromets for like a snap on cover, this might be what you are asking. it would be just an original very low profile version of what the boat had as a top. these types are custom fit covers specifically to your boat. good luck finding one of that age in good condition. you can have Leta's Tops make you one but be ready to dole out about a grand.
cheers
__________________
86' Capri 1950 BR
Force 125hp
Desert Southwest
  #6
Old July 17th, 2009, 11:11 PM
redone4x4's Avatar
Quote:
my bimini has handled strong winds, and running at around 30-40 mph alot. almost every time we go out, actually. after the initial adjustments, it handles just fine.
__________________
  #7
Old July 18th, 2009, 05:54 PM
Bigprairie1's Avatar
Bigprairie1 Bigprairie1 is offline
I have the exact set-up shown in the video on my boat ('90 Capri). What you see there is the aluminum/metal frame that supports the standard full canvas top. When you undo the canvas top from the front of the windshield frame it folds up against the back frame giving the semi-convertable look. Then you roll the canvas over and over the frame (wrap it up basically) and then use the (original) mini-canvas tube wrap thingy (with full boat width zipper) which goes over the rolled up canvas and keeps it in place. I think a lot of these boats have lost their original framework and canvas stuff by now but it appears that guy still has is. I'm fortunate to still have mine as well.
A bimini (which I would like to get at some point) is a little different and you would probably have to remove that existing frame/canvas which is easy. Basically just (2) removable pins releases it and you can leave the whole thing on the dock or then put up your bimini which might use the same two hull brackets?...I'm not sure about that tho'.
My two bits.
Good Luck
BP
__________________
Big Prairie
90' Capri- 90 Force
If it was easy, everyone would be doing it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
98 Bayliner Capri 1800 tpatrick Bayliner Boats 0 June 6th, 2009 03:09 PM
weight on Bayliner Capri 180 1990 model larsst185 Bayliner Boats 2 May 29th, 2009 04:37 PM
1990 bayliner capri 1800 gas tank brodriguez Boat Topics and Questions (not engine topics) 1 April 14th, 2008 04:31 PM
Swim Step extension for 1990 Capri 1800 Illini River Bayliner Boats 3 June 27th, 2007 12:08 PM
1995 Bayliner Capri 1800 Bellybuster08 Bayliner Boats 0 April 23rd, 2006 02:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
