  #1
Old July 16th, 2009, 03:39 PM
SamammishNow SamammishNow is offline
Cool Prop Selection Sea Ray 185 Sport
OK great I just bashed up my first prop and am trying to select a new prop. I've got a 2005 185 Sport with the 190 hp 4.3 L engine. I normally have three people in the boat, roughly 500 lb total. I do everything from touring to pulling skiers up to 200 lb. Someone has mentioned I should replace the 14 x 23P standard prop with a 21P. Anyone have any great prop experiences they wish to share?
  #2
Old July 17th, 2009, 11:28 AM
nlain nlain is offline
Master Chief Petty Officer
Default Re: Prop Selection Sea Ray 185 Sport
I have the same boat, 2004 vintage, the best thing I have done is to put Smart Tabs on mine. I did change the prop after the tabs and got a 14X23 Turning Point prop, I had to Exchange it for a 14X21 to get top speed and wot back. The TP prop is a very aggressive prop and the 4.3L 190 Alpha does not have quite enough power to turn the 23 pitch. My boat with the stock prop will turn just over 5000 rpm, now with the 21P TP prop I am back to the same wot. That is the extent of my prop experience. If you get a 21P prop of the same design as the stock prop you are going to raise the rpm 200 to 400 rpm so you will have to watch the wot so you don't lose and engine from over reving.
When I put the Smart Tabs on my boat I then started using about half throttle to get on plane, got rid of most of the bow rise as in never lose sight of the water in front, run faster, use less gas, low speed wander is gone, handles rough water much better. If you go up in the other forums to Boat Topics and Questions (not engine topics) and Prop Questions and Topics
Do a search on Smart Tabs and you will find a lot of information on them.
The site for Smart Tabs Manufacturer is http://www.nauticusinc.com/ and the phone number is 800-233-0194, You will find the owner posting here and he "John" may even be the one to answer the phone, he posts under jdeargro. I have no interest in Smart Tabs other than being a satisfied owner. You would need the ST1290-60 set and mount the tab bracket in the rear set of holes for a better install. Hope this is of some help.
You should also post this up in the Prop Questions forum.
__________________
http://myboat.wikispaces.com/
2004 Sea Ray 185 Sport, 4.3L,190, Alpha
1994 GMC 4X4 1500, 5.7L
  #3
Old July 17th, 2009, 12:01 PM
jkust jkust is offline
Hi what were your WOT rpm's and top speed with the 23 pitch? Do you know your gear ratio? I have the Merc 190 4.3 in my 03 Chap with the oem 21 pitch alum. Obviously the prop is pretty basic being alum and oem but pitch wise it seems to fit the bill for all around use with a similar load. Only thing is that I easily overrev the motor so I was thinking of making a change as well plus I have been eyeing stainless for a while. My dry weight is 300lbs more and hold more fuel which I usually keep pretty full so you should have an advantage on your selection. My boat is rated to 270hp so really a 190 is already disadvantaged. Interesting nlain says the 23 pitch is too much prop for the 4.3. I always thought that as well but then what do you do with the extra 300 rpm's over the wot limit with a 21? I have seen some boat tests testing with the 23p even ss on carbed 4.3's which always confused me. I think Stingray was one. Anyway take a look at 180shabah's posts. He has the same motor and highly recommends one particular brand of SS prop. I don't recall the name, but when I am ready to upgrade I plan to read his posts since I believe what he says.
__________________
2003 Chaparral 183SS
  #4
Old July 17th, 2009, 01:13 PM
Only the 23P Turning Point prop is too much due to the aggressive cupping, the stock Merc 14X23 will turn 51 to 5200 rpm with just me and just the basics like anchors. The Turning Point 21P brings me back to the same wot rpm range as the stock prop. The 14X23 stock prop was fine on my boat I just wanted a little more speed so I went for the 14X23 Turning Point and lost wot rpm and speed, I did gain speed at cruise. Just to clarify my statement.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop Selection - Prop Wizard Calc Eddie P Prop Questions and Topics 7 July 22nd, 2008 04:04 PM
yet one more guy that needs help with prop selection sprouticus Boat Topics and Questions (not engine topics) 18 May 31st, 2005 02:14 PM
Prop Selection?? 02baylinercapri-NM Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 19 March 10th, 2005 12:29 PM
Need Help with Prop Selection ltedesco Johnson & Evinrude Outboards 1 February 9th, 2004 03:47 AM
prop selection keepiton2 Johnson & Evinrude Outboards 12 June 23rd, 2002 01:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
