Re: volvo 5.0 running cold
You changed the thermostat. What temperature is the engine running at after ten minutes of running? Engines that don't heat up usually have a thermostat that's stuck open. Remove the thermostat, put it in a pan of water on the stove with a thermometer and test it.
