Re: How to verify OMC cobra gear ratio
Remove the drive, turn the input shaft one revolution, count the number of turns the propeller makes.
You'll get a far more accurate number by turning the input shaft 20 turns and counting the prop turns.
The 460 King Cobra was 1.41:1, the 5.7L models were 1.43:1 etc.
Someone here has an OMC service manual and can probably look this up, Most of the drives were rated by ratio and by input turns
utput turns. (For example, 1.41:1 is also 24:17.......24 eng revs to 17 prop turns.)
It's much easier to count 24 turns of the input shaft and 17 turns of the prop vs 1.41 turns to 1 turn (unless you can set up a protractor that reads in degrees)
Unless you have a drive that has an exactly 2.00:1 or other even ratio it's going to be hard to measure it unless you can set up something that measures in fractions of a circle.
Even if you can't remove the drive, you can pull the spark plugs and turn the crankshaft with a socket wrench etc. if it's in gear, you can have a helper count blades on the outside while you count turns on the damper. And then get out your sliderule!!! (or calculator!)
Cheers,
Rick
