  #1
Old July 14th, 2009, 08:50 PM
LevIsak LevIsak is offline
Default Boat Runs Hot when going above 3000rpms, please help
I just bought a 95 maxum 2300 sc, i have 5.0l mercruiser alpha 1 gen 2, with a closed cooling system. i just had it serviced for pretty much everything impeller, new carb, etc..
she idles fine and cruises at about 2800 to 3000rpms at about 160 degrees, if i go above 3000rpms she starts to climb in temp almost reaching 200 degrees.
i cant figure out what it is, niether can my mechanic ive spent over 2grand on her already please help
  #2
Old August 3rd, 2009, 06:00 PM
steve201 steve201 is offline
Default Re: Boat Runs Hot when going above 3000rpms, please help
well..there are a few things to check...is the heat exchanger clear at the tubes???....what thermostat did you put in?? is it new???......most of the time it's the impeller...doesn't mean it was installed correctly...I'd pull the outdrive and check that too.....
Steve
__________________
Steve201
2003 Maxum 2700SCR
Everett, Wa
  #3
Old August 7th, 2009, 01:02 PM
dodgezilla04 dodgezilla04 is offline
its quite possible there is an air bubble in the thermostat housing not allowing coolant to contact the tstat, that will insulate the tstat to some extent and it doesnt open when it should...
  #4
Old August 31st, 2009, 12:58 AM
Lil Dickey Lil Dickey is offline
What is the source of this bubble? Is it introduced when replacinging the thermostat?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Jet boat river runs azlakes Dockside Chat 4 July 11th, 2009 08:08 PM
2001 50hp only run at 3000rpms at full throttle under load please help Logic2001 Mercury & Mariner Outboards 2 July 26th, 2005 12:25 PM
Evinrude 55hp wot only 3000rpms, Did I hurt engine by running?? santuitman Johnson & Evinrude Outboards 6 July 18th, 2005 06:36 AM
new boat owner oil looks milky boat runs but almost dead? Is this a sign the mot charriex2 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 August 2nd, 2004 06:13 PM
engine buzzer goes above 3000rpms dnero20431 Honda & Tohatsu/Nissan Outboards 1 August 25th, 2003 02:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
