alumi numb
- Nov 12, 2008
- 299
how do i remove the cable so i can slide the bellows over it.
thru the exhaust port i see a s.s. rod with an arm at the top and at the end of the arm is a roller.
this sets in a raised section on top of a aluminum long rectangular piece and the shift cable runs into it.
the outward end of this rectangular piece looks like it has a set screw in it that is safety wired.
were do i go from here????
hyd. lines went fine and i see no trouble replacing the driveshaft and exhaust bellows.
the shift cable seems to be another thing, help and thanks.
by the manual it says tighten the screw and then back off 1/4 turn.
is this the screw they are speaking of at the outboard end of the shift fork??
