After hearing nothing but good things about smart tabs I decided to buy a set so I could hopefully obtain a slower plane speed for pulling my young kids on the tube and teaching them how to ski, not to mention all the other benefits of having them.
Now I have the problem of where to mount the things with the hull design that my boat has. If anyone can help I would certainly appreciate it.
Thanks.
As you can see in the pictures below if I center the tab in the 6" area closest to the edge it puts them pretty close to the outside of the boat since the tabs themselves are wider than 6". If I center them in the 2nd 6" area they are considerably farther from the outside then the recommended 5". The only other option is to center it over the first little 3" area, whatever it is called? But I do not know if that is a good idea or not.
Thanks.
