I have a 1975 2-stroke 115hp evinrude that is running on 2 of 4 cylinders. It will sometime start hitting all 4 when I hit a wake that causes the motor to bounce. The next wake I hit, it will go back to firing on 2 cylinders. I checked power to all plugs and its cylinders 1 and 3 (the right half of the motor) that are not sparking. I then decided to check power out of the power pack and found that cylinders 1 and 3 have half the voltage that 2 and 4 do coming from the power pack. I suspect there is a loose wire somewhere but cant find it. I had heard that it could be some coil under the flywheel but know nothing about that part of the motor. Why would I only have power to half the motor? Any suggestions?
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
