I just picked up a 1970 Evinrude Sportwin 9.5 and was doing a test run in a barrel of water. I noticed the water had oil scum in it when I was complete and there was some oily residue on the lower unit when I pulled it out of the water. I am new to outboards and was wondering if this is normal or do I have a bad seal somewhere. Also, I removed the upper gear case oil plug to check the condition of gear oil and then realized I probably should have removed the lower one instead to check the oil. Am I right on this. Oil didn't look too bad, maybe a little lighter in colour than new oil but not milky. Anyone know where this oil scum is coming from and what I should do about it?
