Ok I have fouind that the carb is not getting any fuel into bowl you can prime it and fill the bowl it runs until bowl is empty I am getting no gas back into the bowl. I have replaced the diaphram and spring and also checked all lines for leaks and found none float and needle have also been replaced have not replaced the fuel pump yet could it be bad or or the reedblock perhaps ?
