Mister Tawny
- Jun 20, 2009
- 6
Okay here's my story. I am the new owner of this engine and boat. The engine is a 1970 Johnson 60 on an Invader 16'. We had her running but unfortunately the gas/oil mix resulted in fouled plugs. In the ensuing change one of the plugs required a helicoil. Got that done and then with help from a few friends she eventually fires up but immediately dies out (chug, chug, KOFF, *die*). One of the friends thinks it may be a lower end issue with the shaft engaging and killing her like starting in gear. I don't see how that can be the case.
My thoughts are there is either an issue with a solenoid or simply the motor is not set right. Any help for an iboats forum newbie is gratefully appreciated.
