6HP Evinrude year and model#
FredCWO
Does anyone know where the model# is located? I just bought a mid 70's 14' Starcraft boat with a 6hp Evinrude motor and was trying to figure out what year it was. I don't see a model# any where. On the top of the motor it says set points to .020
iwombat
Re: 6HP Evinrude year and model#
model # is both on the port side of the transom bracket, and on a silver disk on top of the powerhead (usually just behind the head).
points set at .020 isolates that to _at least_ between 1950 and sometime in the mid 70s when they stopped using points :)
FredCWO
I see a number stamped under where the motor mounts which is 278619. I'm not sure if it's the correct # which would indicate year of manufacture or not. I didn't see a tag behind the head anywhere. Is that number just a part# for the engine compartment or for the motor? Thanks, Fred
iwombat
That's likely just a casting number. You should be able to see a metal disc on the powerhead, smaller than a quarter, with both the model # and serial # on it.
FredCWO
I see a number stamped behind the power head but not sure it's the correct number I'm looking for. I don't see a disc at all. I see 312714 1
