No Spark/Good spark/Intermitent spark 3 cylinder mariner 75hp
Hi, hope some one could help me out here. I have a 1990 Mariner 75hp 3 cylinder outboard. The engine has been starting with no problems this year on trailer (boat not been out this year). Started fine Wednesday, tried Thursday but would not start. Have narrowed problem down to electiccs and ignition. have disconnected wiring harness and am starting from a switch direct from engine. I have a good spark on bottom cylinder, no spark on middle cylinder and a very intermitent spark on top cylinder. I have alternated the wiring from switch box to coils, spark will move up and down the coils, so presume they are ok. If I transpose the trigger wires, ie move the second wire to the top, that sparks, if I move the bottom wire on switch box to the top, that will fire the spark, but cannot seem to get a spark from second/third wires/cylinder. Could this be a switch box problem?, or what else could it be?, I have limited test equipment, an ohmeter, volt meter but nothing else, any help would be greatly appreciated, many thanks
