  #1
Old July 13th, 2009, 02:51 AM
Doolin's Avatar
Doolin Doolin is offline
Send a message via Yahoo to Doolin
Question How Do I flatten a Dent In the Bottom of My Aluminum Hull?
Hi All,
I was looking at the bottom of my boat for the source of a leak. I noticed a fairly sizeable 'dent' in the hull. It's basically circular shaped, a little over a foot in diameter and maybe better than an inch deep. It's pushed up, from the outside, into the boat.
The boat is an '84 Valco runabout. Sort of like a john boat but there is a shallow V to the hull. The floor boards are marine plywood held in place with stainless steel screws. The seats are also marine plywood but rivited to the aluminum bases that are welded to the hull.
I will be removing all of the seats and floor boards to seal the seams with Gluvit. While I've got everything out... I'd like to flatten the hull.
The question is... can I just pound that back flat? Do I need to use a 'softer than aluminum' hammer or use a hammer on a piece of hardwood to return it to shape?
Any suggestions would be appreciated.
Thanks!
__________________
__________________________________________
In Theory... there's no difference between theory and practice.
In Practice... there is.
Ben
  #2
Old July 13th, 2009, 02:56 AM
buddybarnhill buddybarnhill is offline
Default Re: How Do I flatten a Dent In the Bottom of My Aluminum Hull?
i would use a peace of hardwood and a hammer but be gentle dont go breaking brick apart if you know what i mean in nothing else consult a body shop for some of their ideas
  #3
Old July 13th, 2009, 05:52 AM
5150abf's Avatar
5150abf 5150abf is offline
I personally wouldn't mess with it, older aluminum gets kinda hard and brittle and it is really hard to work with, chances are you will beat the snot out of it and just make your one big dent 50 little ones.
I have heard of guys heating the aluminum then pounding it out or putting dry ice on it, the sudden cooling makes the metal contract and get straighter.
I work with new aluminum boats and have done alot of repairs and it is really hard to work a dent out, like I said I would probably leave it alone so all the pounding doesn't loosen more rivets or anything.
__________________
GO IRISH!!!!
  #4
Old July 13th, 2009, 10:14 AM
SKEETR SKEETR is offline
It is amazing how much force is needed to pop a dent back in a hull. When I did one on my boat it took two of us. Unfortunately for my boat the dent was directly under an aluminum stringer. I took a 2x4 and held it up to a good side of the hull and transferred the radius then cut it out. Then placed it against the hull at the dent location. With some additional bracing and a jack I was able to get it to sit tight to the hull while my buddy (in the boat) proceded to hit the dent from above with a mini sledge. After several swings it became obvious that we were underpowered. So we broke out the the big sledge and with several full swings and some repositioning of the brace we got the hull back to shape. That 1/8 stuff is stronger than it looks.
  #5
Old July 13th, 2009, 01:18 PM
Doolin's Avatar
Wow. I'd really like to have the bottom of my boat flat... I guess I have an idea now of what it'll probably take and an an idea of how to get there.
Thanks!
__________________
Ben
  #6
Old July 14th, 2009, 05:56 PM
5150abf's Avatar
I still wouldn't mess with it, all that banging is bound to do more damage than you fix with making rivets leak.
__________________
GO IRISH!!!!
  #7
Old July 14th, 2009, 06:44 PM
Doolin's Avatar
I would definetly be more concerned about leaks than dents... but this hull is all welded.
Are welds likely to crack from pounding that isn't directly on the weld? The dent is about midway from the center of the boat to the side.
__________________
Ben
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
dent in bottom of basstracker...help!!!! dave72 Boat Restoration and Building 2 July 24th, 2006 09:35 PM
Aluminum Dent Repair Gone Boat Restoration and Building 4 February 13th, 2006 04:04 AM
Hull Dent Repair? -- 25' Chieftain rick1969ca Starcraft Boats 0 December 10th, 2005 09:55 AM
Aluminum flat bottom Hull Vibrating tee-boy Boat Topics and Questions (not engine topics) 1 May 17th, 2004 12:08 PM
Hull Dent Troy_from _Oz Boat Topics and Questions (not engine topics) 5 May 14th, 2003 07:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
