  #1
Old July 13th, 2009, 12:02 AM
Dandamanf15 Dandamanf15 is offline
Default 74 Mercury 1150 loss of fuel
Hi there. This is my first post on here. I just recently bought a boat with a 74 Mercury 1150 serial# starts with 376. First time we took it out (saturday) it ran great for about 5 hours, then started to stall. After putting it in neutral and then going again, it would run fine for a few minutes, but then if i tried to really open up the throttle it would start to die again. Anyway, we realized we were low on fuel, so we added fuel and it ran great on the way to the marina to get filled up until right before we got there, and then it died and wouldn't start. We took the fuel lines apart last night, and tested the squeeze bulb-working fine. I forgot to mention earlier that squeezing the bulb while trying to start after it died didn't help. After taking apart the fuel lines and checking for blockage, putting it back together, and spraying a bunch of carb cleaner while trying to start it, we got it going. Today we took it out to test and it ran great for 30 mins or so, even at WOT. Then had the same problem. Ran ok at idle, but opening the throttle up seemed to starve it. We made it back by spraying carb cleaner when it would start to die.
Don't know where to go from here. Should we go ahead and try to rebuild the carbs? Because it seems like we have good pressure up to the carbs. My best guess would be that when we ran it out of gas, some gunk got caught up in the carbs.
Thanks in advance for any help!
  #2
Old July 13th, 2009, 12:14 AM
FTomazinis's Avatar
FTomazinis FTomazinis is offline
Default Re: 74 Mercury 1150 loss of fuel
It could be you have air leaking into the fuel line somewhere at a connection. Also there should be a screen at the pick up line in the fuel tank. There is also a screen in the carb. I would check these first
  #3
Old July 13th, 2009, 12:18 AM
Ok thanks a lot I will check those things and see if I can find any problems
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
72 Mercury 1150 loss of power 72gt150 Mercury & Mariner Outboards 5 July 13th, 2007 12:09 PM
76 Merc 1150 - RPM Loss kmanster00 Mercury & Mariner Outboards 3 July 16th, 2003 06:55 AM
fuel problem 1150 mercury bigbadbomber Mercury & Mariner Outboards 2 April 24th, 2003 08:10 PM
*** 1976 Mercury 1150 115hp - ENGINE DIES AFTER STARTING. FUEL PUMP PROBLEM? HEL brianmerc Mercury & Mariner Outboards 15 November 11th, 2002 09:01 PM
1971 mercury 1150 leaking fuel at bottom carb. djwinter Mercury & Mariner Outboards 2 July 26th, 2002 11:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
