First....my outboard is a 1988 Mercury Inline 6 "Tower of Power" - 115 hp
After pulling a tube at 4500 rpm WOT for about 10 minutes, my engine acted like it was running out of gas and stumbled back to 2000 RPM for a few seconds before resuming at 4000 rpm. I pulled back the throttle to idle speed and checked the motor and saw that it was not "peeing". I immediately shut down the motor. I assume that the water impeller has failed since it no longer shoots water out the pee hole.
After being towed back to the marina, I checked compression and found the cylinders 1-5 have between 110-117 psi...however, cylinder #6 has ZERO pressure. It also shows a clean spark plug and it seems to have water droplets on the spark plug.
It is possible that #6 had slight water intrusion before this incident because #6 also looked "clean" a few months ago when I changed the plugs.....but at least then it have over 100 psi.....perhaps this episode made a moderate problem much worse.
I assume that a rebuild is in my future .....how bad is this and how much is it likely to cost to pay someone to fix it? Although I have some mechanical ability, I think this issue is probably over my head.
