Re: postion of engine on the toon
Ya, sounds like your engine is a bit high, drop it down a couple holes.
There is one set of holes in the boat and there should be several on the motor itself, go to the lowest ones and hope that does it.
That is called cavitation and is caused by the prop being to close to the water surface, it wants to push the water but there isn't enough to push so it blows out.
__________________
GO IRISH!!!!
