  #1
Old July 11th, 2009, 10:50 PM
dogwood2 dogwood2 is offline
Wink Sputtering problem
1999 5.0 mercury in/outboard motor for a Chaparall, having a problem and need some help. Cranks fine, idle may vary, runs good to 3000 steady rpms, then starts surging and sputtering. If give rest of gas, seems like starving for gas and just sputters. We are new boaters and just wanted to see if anyone had a suggestion. We thought gas may have had some water or ethanol. Thanks. jc
  #2
Old July 12th, 2009, 10:25 PM
a70eliminator a70eliminator is offline
Default Re: Sputtering problem
10 yr old boat when is the last time it had a tune up? Carefully remove the fuel seperator and pour it contents into a clear jar and that will tell you if there is water in the fuel.
  #3
Old July 13th, 2009, 07:41 PM
TilliamWe TilliamWe is offline
Ethanol is not the problem. And people that tell you it is, are just hyping.
You could have amirad of problems. But fuel delivery seems to be the most obvious. After checking/replacing the water/fuel separator, then you need to see if it's actually getting fuel to the carb. There is a yellow tube that runs from your fuel pump to the carburetor. if the fuel pump has failed internally, this tube will have gas in it, and it's not supposed to.
Another fuel line clog issue takes place at the top of the fuel tank, where the pick up tube comes out. There is a little check valve in there that keeps the gas from draining out of the fuel lines on the engine and back into the tank. Debris can make that check ball get stuck.
Good luck with your Chaparral.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Low RPM sputtering Hardcore Johnson & Evinrude Outboards 3 February 13th, 2009 09:01 PM
suzuki dt140 sputtering problem bagel Yamaha & Suzuki Outboards 7 February 10th, 2009 11:35 PM
90 hp Yam. sputtering sduffy Yamaha & Suzuki Outboards 1 July 4th, 2008 02:02 AM
Sputtering on the water rplky Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 June 8th, 2006 07:16 PM
sputtering at wot ptbus Johnson & Evinrude Outboards 0 May 30th, 2005 07:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
