  #1
Old July 11th, 2009, 05:09 PM
gwalkgwalk gwalkgwalk is offline
Default 85 bayliner Ciera. Electrical issues
I have an 85 bayliner Ciera. Great boat. My question was on the electrical setup. I try running the power cord to the house and the only thing that works is the outlets. Is this because I am missing the battery charger?? If so where can I find one that will work in this boat. Thanks
  #2
Old July 12th, 2009, 02:53 PM
gcboat gcboat is offline
Default Re: 85 bayliner Ciera. Electrical issues
Those outlets are the only things on your boat that's wired for 110 volts. Everything else will be 12 volts. There are some occasions where one - maybe two - lights would be hardwired into the 110 system but that would more than likely be an aftermarket item installed by a PO.
And no - a battery charger will have no effect on any 110 volt system.
If for some reason your battery grounding wire is loose or corroded then you might have some issues with your 12V system.
Check it for tightness and cleanliness. Do both of them - the battery and the block ground.
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
  #3
Old July 12th, 2009, 06:05 PM
Thanks for the advise. Let me just add a little more info to this. As of right now I don't have a battery charger hooked up in the boat. The guy I bought it from told me I could buy one at walmart. If I had a charger hooked up would I be able to run all electrical items when plugged in? Because right now I am have the batteries turned off at the kill switch in the engine compartment. But if I had the charger hooked to the batteries then everything should work then??? I don't know maybe I'm over thinking this!!! Any ways I asked someone who has a newer model cruiser and he told me he has a Flyback 10-3. If u look this up on eBay it is selling for 60. I was just wondering if there was any other place that would sell something similar?
  #4
Old July 12th, 2009, 06:34 PM
I do believe you are indeed "overthinking" this. So for the sake of brevity here we go.
All of the outlets in your boat are 110 volt - shore power operated. Has NOTHING AT ALL to do with your batteries - NOTHING !!!!.
With your shore power cord plugged in they will work. With the shore power cord NOT plugged in they won't.
There are two different and distinct electrical systems on your boat.
110 volt and 12 volt. Your 12 volt system is operated from your batteries. This will operate all of your electronics and the interior cabin lights. It will not make the outlets HOT ( they're 110 volt shore power - OK? )
Now, once again. A battery charger will NOT activate the outlets - it is a completely different circuit - .
So, to recap: shore power plugged in, outlets work. Shore power not plugged in, outlets don't work.
Of course if you have a generator on board that theory goes out the window.
We thinking along the same line here????
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
87 24' Bayliner Ciera?? Salt Life Bayliner Boats 5 April 6th, 2009 02:48 AM
Bayliner 2855 Ciera HondaPower Boat Topics and Questions (not engine topics) 5 March 5th, 2009 04:56 PM
96 Bayliner Ciera black95jimmy Boat Topics and Questions (not engine topics) 3 April 30th, 2007 09:07 PM
1988 Bayliner Ciera OMC 5.7 L imported_Dragonfly Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 November 2nd, 2006 09:29 PM
Bayliner 3055 Ciera gnaquin Boat Topics and Questions (not engine topics) 1 May 30th, 2004 07:35 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
